no AC, no AIR pump.. need new serpentine belt.
Old Jul 19, 2001 | 05:54 PM
age's Avatar
age
Car: 1992 Z28 1LE
Hey guys, I read over the tech article about removing the AIR pump, and the author had given a part # for the new belt. HOWEVER, his setup had air conditioning.
The AIR pump has been removed on my engine, and I have no air conditioning. I'm assuming that I will need a different belt than the one subscribed in the tech article.
Does anyone know which Delco part # I need? Thanks! Oh yea, I have a 92 Z28.
Old Jul 19, 2001 | 06:24 PM
rezinn's Avatar
Just run a string around it to find out how long it needs to be, and count the number of grooves the belt needs. Any dealer can tell you the part number from those two pieces of info. I know how some other manufacturer part numbers work, but not delco.
Old Jul 20, 2001 | 05:18 PM
FasNuf91's Avatar
i want to pull my a/c and smog pump out but i am not sure how to route my belt...some info will be great
Old Jul 20, 2001 | 11:18 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
An easy thing to do is to buy an AC delete pulley and just follow the routing that madmax put on his tech article. Otherwise just follow what rezinn said grab a piece of string and do it that route. My friend just deleted his AC and Smog and got the pulley to throw in there and it worked really well and it was pretty easy since the number was listed for us and how to route it. Good luck.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
