Hypertech HEI cap
Old Mar 23, 2005 | 02:12 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Hypertech HEI cap
I see the coil is in the cap how do i hook this up to my car? What wire goes to the coil on the cap?
Old Mar 23, 2005 | 08:29 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
My guess as to why you can't find the wires you need is that you don't have those wires. Because unless someone changed your '88 to a coil-in-cap ignition, it should have the separate side-mounted ignition coil, not a coil-in-cap.
The last year for coils-in-caps was 1986(and some early '87s). The separate ignition coil came in 1987.
You can get just the coil, or you can get the coil in a package that also comes with a cap and rotor(part #4054).
Old Mar 23, 2005 | 09:57 PM
trueburton's Avatar
ok my car does have the coil off to the side. I wasn't sure how this worked. Like if i was supposed to have both installed at the same time or if icould remove the other one or what the deal was. So i need to buy an Ignition coil and a cap w/ rotor?
Old Mar 24, 2005 | 12:00 AM
LAFireboyd's Avatar
If you don't want or need a new cap and rotor, you can buy just the coil(Hypertech part #4052). If you want the package containing all three parts, it's #4054.
Old Mar 24, 2005 | 09:27 AM
trueburton's Avatar
It's been about a year and a half since replacement. It was a cheap Wells cap and rotor. Should i replace?
Old Mar 24, 2005 | 11:28 PM
LAFireboyd's Avatar
It wouldn't be expensive to go ahead and change them. And with the new stronger coil, I'd change them just to make sure I'm getting the most out of my ignition. But maybe that's just me.
Either way, you'll probably be fine.
Old Mar 24, 2005 | 11:34 PM
trueburton's Avatar
thanks i'll prolly just do them all at once
Old May 22, 2005 | 06:50 PM
badCHEVELLEman's Avatar
Car: chevelle + camaro
Engine: 520hp 350 350
Transmission: th 350 700r4
Axle/Gears: 4:56 3:23
is anyone using this kit (4054) from hypertech i was looking at getting this or a msd cap rotor kit (8406) and coil (8226) what do you think of each kit hypertech says 53,000 volts and msd says 45,000 both comes out to about the same price
thanks for the input
Eric
Old May 22, 2005 | 09:22 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
From what I hear, you can't really go wrong with either MSD or Hypertech as far as ignition goes...
school boy
Oct 22, 2015 11:47 AM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
