EGR question
Old Jul 20, 2001 | 12:45 AM
My305camaro's Avatar
EGR question
My car's "Service engine soon" light comes on a lot now and it's always old code 32. I just recently, by some stroke of luck, lost my smog stuff and all the guts of my converter some how fell out. Does that have anything to do with the constant code? Also I'm thinking of swithing to a non-EGR intake and dumping the EGR all together since it doesn't work now and it doesn't seem ot hurt me (no ping). Is this possible/wise? Any long term damage? I don't have to pass emmisions here in VA, so that isn't a concern.
Thanks in advance for the help!!!
1991 Chevy Camaro RS TBI w/auto
Mods:
Edelbrock TES Headers, REALLY high flow cat, 2 1/2 in catback flowmaster, 160 stat, hypertech chip, MSD ignition (rotor, cap, superconduct. wires), Bosch quad4 plugs, open air filter, all TBI mods, no smog stuff, no EGR, lots of suspention and alignment upgrades, and a big Chevy bowtie sticker on the back.
Fastest e.t.:
15.68 @ 87.3mph
Old Jul 21, 2001 | 10:01 AM
Vader's Avatar
Your low exhaust backpressure may have affected the pilot valve in the EGR valve. The EGR may not open without adequate pressure in the exhaust, and the ECM does not see the anticipated change in MAP signal when the EGR is supposed to be turned on by the ECM and EGR solenoid.
You should also check the EGR vacuum solenoid valve to make sure it is working and that the EGR valve itself is opening. There should also be a vacuum source at the EGR solenoid valve.
If the EGR or intake manifold ports are coked with carbon, the EGR opening will not have the desired effect. The MAP will not detect the pressure change and set the code.
You could run without the EGR, but it DOES help keep the chambers cooler and allows more spark advance.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
