The Fuel Thread
Old Mar 24, 2005 | 09:57 AM
NeonPinkDragon's Avatar
The Fuel Thread
I was discussing current gasoline prices with an associate of mine, and he comes out to state that he only purchases unleaded fuel from Mobil or Exxon stations. I found this perplexing to say the least . Are there any advantages or disadvantages of purchasing one distributor's gas versus another's? Is there a difference between fuel quality obtained at your Local Shop-Qwik vs. a national distributor?
Many thanks to all for answering my questions.
Old Mar 24, 2005 | 10:12 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
all fuel in the US comes from about 7 different refinerys. (well, make that 6 now.......) While there are some variations in the mix, gasoline if HIGHLY regulated by the govt. for content, additives, etc. I would guess that you could get gasoline samples from several different gas stations, and find very little difference in the blends....... (all being the same octane rating.)
Old Mar 24, 2005 | 10:58 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
From the AP report on the explosion: "About 433,000 barrels of crude oil are processed a day at the plant, producing 3 percent of the U.S. supply." That's a lot less than 1/7th.
There may be 7 different companies refining crude, although I don't know that for sure.
For the daily drivers, I look for the least expensive. There's an independant about a mile from my house where I do most of my fueling, I've never noticed a difference when I happened to get gas somewhere else (and I keep records on all 5 vehicles in my "fleet"). For the "race car", though, I always get gas at Phillips 66 or Conoco, just for the sake of consistency - and it probably doesn't really make much difference.
One of the biggest differences, here at least, is what they use for the "oxyginated additive" - MTBE, or ethanol. MTBE is nasty stuff.
(FWIW, Exxon Mobil doesn't operate here.)
Old Mar 25, 2005 | 11:37 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Not sure if it's the same system over in the USA but here, almost all petrol comes from the same source. However different companies have their own additives that get mixed in with the fuel when they fill up at the refinery. These additives are probably not going to be noticed in SBC engines but probably have more impact in fancy modern engines.
The only difference that you may notice between different "brands" is how much dirt etc is in their tanks.
Si.
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Linson
Aug 21, 2015 02:12 PM
92camaroJoe
Aug 13, 2015 06:07 AM
