Is My EGR Stuck Wide Open ?
Old Jul 20, 2001 | 10:31 PM
GTA88's Avatar
Here are the symptoms :
A). Car starts, but won't idle. You need to keep feeding it gas to keep it running.
B). Car stalls out under 15 mpf unless you keep feeding it gas.
c). Car runs OK if you are going over 40 mph.
d). Horrible smelling blue exhaust. Not billows of blue like an oil burner, but definitely some blue smoke and an awful smell, hard to describe, like something coming out of a factory.
How can I check the EGR, to see if it is stuck ?
88 GTA Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Jul 20, 2001 | 10:54 PM
iroc5speed's Avatar
well, you could always take off the egr and put vaccuum caps over all connectios with it, and also make sure to seal up the hole in the manifold so there are no vaccuum leaks. After making sure to do all of this, then see if the car is doing the same thing and if it isn't then your egr is stuck. (it may seem like a lot of trouble but it shouldn't take very long to do.)
Old Jul 21, 2001 | 07:22 AM
GTA88's Avatar
Yeah, but get to the EGR I'll have to remove the plenum. Is that a big deal ?
Old Jul 21, 2001 | 04:51 PM
Enkil's Avatar
I'm assuming you have a TPI, not a TBI or carb. It's a bit more involved in TPI cars, you'll have to take off the plenum and at least one of the runners.
If it IS stuck, capping the EGR might not do anything.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jul 22, 2001 | 01:20 AM
Omar's Avatar
Just disconnect the EGR solenoid by the distributor.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
Numbah-1
Sep 12, 2015 08:57 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
