What is the best spark plug?
Old Jul 22, 2001 | 01:05 AM
CamsCam's Avatar
I have a '91 305 z28 5-speed. It is stock for the most part. What is the best spark plug to use.
Old Jul 22, 2001 | 02:34 AM
84TransAm's Avatar
A new one
Seriously: Unless you're running something that's been seriously modded and is running low ET's then any "non-performance" spark plug is fine. I like to use AC Delco since they're what our cars rolled out of the factory using.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
350 ready to get in and run as soon as i find a WC T5.
Old Jul 22, 2001 | 02:48 AM
Dan87IROC-Z's Avatar
Anything made by AC/Delco. I use the Rapid Fires and like them a lot, I also know a lot of people who use the AC platniums and have good luck.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, LPE High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Jul 22, 2001 | 02:56 AM
Guest
Guest
Posts: n/a
The cheapest AC delco plugs you can get your hands on that are new. Dont waste your money on anything else.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
