LS1 beehive springs?
Old Mar 25, 2005 | 04:16 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Anybody know anything about LS1 valve springs? I got a set here i want to use for cam break-in or maybe run. I am installing a XS-262S solid mechanical cam with .477 and .488" lift, but i'm adding 1.6 ratio roller rockers. So thats .509" and .520" Can the stock beehive LS1 valve springs take that kinda of lift? What is the installed height? Wheres coilbind? What are the spring rates? Anything really.
The springs are going on retrofitted aluminum LT1 heads on my 305.
Could stock LT1 valve springs work?
Old Mar 25, 2005 | 11:26 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
the stock ls1 springs are not very stout pieces. i would deff advise you to not run them with a solid tappets cam.
Old Mar 26, 2005 | 02:13 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
What is the max lift? Installed height?
Old Mar 26, 2005 | 03:23 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Anybody know max lift?
Old Mar 26, 2005 | 03:39 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Do you know the installed ht?
If so, compress the spring in a vise or a c clamp til it lightly coilbinds then back it off til there's about .060 between coils, or some say .10 total (which never added up to me) and that should give you the max lift.
Other than that, the max lift limitations would be in the head itself.
Hope that helps
87v6Bird
Jul 1, 2018 04:12 PM
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
customblackbird
Oct 1, 2015 04:30 PM
86White_T/A305
Sep 21, 2015 05:28 PM
sandman92084
Sep 12, 2015 10:27 PM
