Squeeling A/C problem!
Car: 89 Formula
Engine: 355
I recently had my original AC compressor start squeeling real bad and drawing the engine way down. I figured I had a bad AC compressor and decided to replace it and do the 134 conversion at the same time. I replaced the compressor, accumulator, orfice tube, and all O rings. I had system evacuated and recharged with 40 oz's of 134 and I added 2ozs pag oil to compressor, 1 to condensor, 2 to accumulator, and 3 to evaporator (these numbers were on the instructions sent with compressor). I than manually turned the compressor over 15 or so times. The system got to around 40* in the shop.
The problem I am having is the AC compressor still squeels like a pig but only after it has been running and I shut the car off and restart it 15 or more minutes later. I replaced the tensioner since it was 12 years old thinking that would help. The low side cycling switch also took a dive a couple days ago. The pressure is around 30 on the low side and 250 on the high side when cooling. The compressor is a 4 seasons reman that is kind of noisy when running now.
any suggestions would be great.
please help it is hot here!
thanks,
Mark
thanks,
Mark
Car: 89 Formula
Engine: 355
The serpentine belt is very tight courtesy of the new tensioner. I figured that was the problem also.
any other thoughts anyone???
Car: Take
Engine: Your
Transmission: Pick
Is the front of the compressor wet? Four Seasons is known for being a sucky compressor. What it sounds like is the shaft seal is leaking already, and getting A/C oil on the clutch surface allowing it to slip.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
BikeFarm
Aug 11, 2015 11:35 PM
db057
Aug 11, 2015 10:11 PM
