okay help me out guys please
Old Jul 22, 2001 | 04:39 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
my exhaust was popping and the car was running like total crap, i replaced the cap and coil and the exhaust no longer pops and it runs a lot better, problem is it still makes a poof poof sound under the hood every once and a while when i hit the 4bbl, what would cause it? it doesnt do it every time i hit the 4bbl, but it does it often, it's a rochester computerized with a performer manifold.
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Jul 23, 2001 | 05:38 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
update, it makes the poof sound with or without the 4bbl like it's backfiring or something.
[This message has been edited by 86Z (edited July 23, 2001).]
Old Jul 23, 2001 | 08:12 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Any problems when you turn the car off?
Im thinking if it was a vac leak it would be more of a POP instead of poof.
Turn the timing down a few degres and see if it helps.
SSC
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
