How to reseat valves
Old Mar 27, 2005 | 09:43 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I just bought a used set of 416 heads off ebay, i am going to be installing new valve springs and seals. I have never worked on a head before so this will be a learning experience for me. I was told that i will have to reseat the valves, and that i will have to have a valve grinding compound. Does anyone know the correct way to do this and the full procedure? Or if it even needs to be done? I tried a search and didnt have any luck.
Old Mar 27, 2005 | 11:03 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
What has been described to you is called "Lapping in" your valves. Is it necessary? Well, take you head, put it on a stand of some description, and fill the chanber with water. See how fast it leaks out. Take a while? Do your springs and forget it. Gone a a couple minutes or less? Time for a valve job.
Since you have the heads off, and they are used, having a valve job done *just to be sure* is an excellent idea. Having them cleaned, etc. doesnt hurt either. All depends on how *used* they are.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
