305 TBI firing order problems (I think)
Does anyone have a diagram of the TBI firing order?
I let my mom use my car and the water pump went out, and naturally she didn't notice the temp gauge so I blew a head gasket. I took it to a mechanic and he put on a new water pump and a new gasket. He also replaced the plugs and said napa didn't have the wires in stock so I bought some and took em off one at a time and replaced them the same way he had them. But the car is misfiring bad. I sounds like it has a monster cam in it.
So I'm guessing (hoping) that this may be the problem. So if anyone has a diagram I can look at to check this, that would be great.
Also any other ideas on possible problems would be appreciated.
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
If you have the stock intake manifold, the sequence should be stamped on the top in front of the filter.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Performance:
Electronics:
As you stand in front of the car, #1 is the front-right cylinder. #2 is front-left. From there the #s get higher as you go to the back of the block.
Ok so now I got the firing order and I know how to count them, how do I know where they are placed on the dist. cap? Or is that labeled too? Sorry I don't know a whole lot about this, plus it's dark and I couldnt tell if they where numbered.
Car: 89 IrocZ
Engine: L98-ish
Stock location for #1 is just to the right (viewing from the front) in the front of the cap, next to it, on the left, is where the #8 plug wire goes, continue around clockwise in regards to the firing order.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I did a search and found this for you.
https://www.thirdgen.org/messgboard/...ML/001797.html
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
