Everyone with an Accel intake base, I need help!
Old Jul 22, 2001 | 08:52 PM
Dan87IROC-Z's Avatar
I can't seem to get my PCV valve into the spot in the intake, it just won't go in. Its like the port for it on the new base is too small or something. Did anyone else have this problem? What did you do? Or what can I do?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, LPE High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Jul 22, 2001 | 10:12 PM
james_fearn's Avatar
The PCV valve goes in the valve cover. The nipple fitting for the PCV valve vacuum line goes into the intake. I used the nipple fitting supplied with the intake. At first I had a hard time making it fit but eventually, 5 min., I managed to finaly get it in. I agree that I was a bit frustrated with it at first, thinking it didn't fit, but eventually it went in.
Another problem I had with my intake is that the front edge of the intake stuck out too far in my 1985 v-belt setup and contacted the bolt for spacer for the alternator. So you may want to check for that.
My accel runners also contacted my fuel rails so I had to do some grinding there too.
...and some of the brackets/supports that bolted to my manifold also had to be modified severly to work with the intake base.
Good luck.
James
1985 Z-28, 350 TPI, T-Tops, edelbrock 6085 heads, ZZ4 cam, accel base/runners & 24 lb/hr inj., ported plenum, everything gasket matched, crane AFPR, SLP 1 5/8 headers, single 3" flowmaster catback, 3" Catco cat, modified tranny, 165 ECM & ARAP code, MSD 6AL/wires, edelbrock STB, Spohn SFC, GW "wonderbar"
Old Jul 23, 2001 | 01:23 AM
Yeah, I didn't get a new fitting with my intake. Should I call Accel and ask them about it? Thanks!
L98 TPI 350 (5.7L)
Old Jul 23, 2001 | 10:14 PM
btt
Old Jul 23, 2001 | 10:44 PM
It's worth a try. Since I didn't use my old fitting I can't verify if the threads are the same, but they look about the same, 3/8 NPT.
James
Old Jul 24, 2001 | 01:36 AM
okay, thanks, I guess I will call them tomarrow.
L98 TPI 350 (5.7L)
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
BAMiller
Sep 14, 2015 06:38 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
