dieseling/knocking sound
Old Mar 28, 2005 | 06:09 PM
theaddkid2004's Avatar
Car: '91 firebird
Engine: 5.0L V8
My 1991 305 tbi firebird makes a dieseling/knocking sound that sounds like it is comming from the engine. It happens when i press the accelerator but then stops after a little bit. It happens more if i press the accelerator down just a little bit. The sound doesn't happen in neutral or when it is ideling. Thanks the help
-keith
Old Mar 28, 2005 | 06:15 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Sounds like the typical pre-detonating. Check to see where your timing is at, check to see what it does when your bring up the rpm's also. Parts inside your dis may be going bad casuing the timing to jump around if this just happened all of a sudden out of the blue, but if you;ve been messing with the timing, it's possible you just put too much in it. Stop now before you burn a hole in your piston.
Old Mar 28, 2005 | 07:55 PM
Haggard's Avatar
Car: Aquiring a Thrid Gen soon
Also you could have a rod knock... Does the knocking get faster as you accelerate?
Old Mar 28, 2005 | 08:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That's what I was thinking also. A rod knock isn't usually heard at idle or when held at a steady rpm but only when you rev it up. I've heard lots of rod knocks in diesels.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
