Cam suggestions, please!
Car: 91 camaro
Engine: 383
Ok, here's the plan:
*rebuilt 355
*corvette alum heads, ported, polished, oversized valves, 2.00 in, 1.60 ex
*Accel Superram base
*edelbrock TES
*3.73 gears
What cam should I get? I'll be getting a set of roller rockers, either 1.5 or 1.6 depending on the cam. I've been told that Comp 305 cam will work well with my setup, what do you guys think? Any other ideas/recommendations?
91 Z28
Come see The Vicious...
*rebuilt 355
*edelbrock TES
*3.73 gears
91 Z28
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
if you can afford it, I would go with one of the lingenfelter cams designed for the SR and vette heads. They are like 211/219 duration and .525 lift.
The ZZ9 from TPIS and this cam (if you get it ground on a 112lsa) would also work. http://www.compcams.com/base/process...?Known=xr270hr
The comp is pretty stout. Its close to a hot-lt4 cam.
[This message has been edited by jcb999 (edited July 24, 2001).]
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You will make the most power with the LPE 219 cam. Get your lower intake ported or extrude honed also, to take advantage of the cam.
Car: 1989 C4
Axle/Gears: 307
With the 355&3:73's you can go higher on the duration and still have tq so I would reccomend these.
ZZ4, melling MTC 2, melling M22210 <-- old lt1 cam just under a different brand, comp 270H almost same as M22210.
SSC
SSC
junkcltr
Aug 2, 2019 11:12 PM
