Never thought to replace the ignition module with a better one...should I?
Old Jul 23, 2001 | 04:24 PM
crazeinc's Avatar
I've got an Accel Super Coil on my 355 right now and I'm soon going to be adding a MSD Digital 6 (for the start retard, the nitrous retard, the rev-limiter, and the spark increase)
I have a stock module in there now. Should I think about getting a matching Accel module and if I should, am I looking at more power, more efficency, better spark, what? Never really read anything about them.
Thanks.
1990 GTA
-355 carb'd, nicely reworked '64 vette heads, 2500 stall, 4.10's, other small things.
-Alston SFC's, Eibach Pro-kit, Koni's all around
-100+ nitrous shot
-Cruising in style with leather and nice stereo.
Old Jul 23, 2001 | 04:32 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I believe you might get some higher RPM response out of them; don't know if they're more streetworthy or not. FYI, Holley also makes a module... hunt 'em down at http://www.holley.com under their Annihilator ignition systems, then under Parts & Accessories. Ah heck, here's the "Parts & Accessories" link- scroll down until you hit the 891-101 thru 891-103. I'm not sure what #891-104 is for...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jul 23, 2001 | 05:39 PM
iroc5speed's Avatar
it's a good idea to get the ignition module that matches your coil. there's an article on that in the new super chevy.
Old Jul 24, 2001 | 10:34 AM
crazeinc's Avatar
Yea, I read that and that's what got me thinking about it.
Old Jul 24, 2001 | 08:51 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Yeah I have the accel coil on my car too, and I've only gone through 3 stock ignition modules, so I opted for the accel module myself.
Old Jun 8, 2002 | 07:19 PM
Sena'sIROC's Avatar
StngKlr,
I'm drudging this topic back up as all the posts I've read dealing with our Ignition Control Modules never end with a definite/positive solution. Which I now have to wave the
You say that you've killed 3 ignition modules in the past, and now you've gone with the one that matches your coil; which is Accel.
Did this work for you?
I too have now encountered this problem. I am using a MSD Digital 6 Plus ignition box, Accel Supercoil on a MSD 8366 Pro-billet distributor and I have eaten three stock AC Delco ICMs.
They will go out without warning leaving me with a no start condition and sometimes shut the car off as if you were to just turn the key off in the middle of driving.
Now I keep hearing of matching the IC module to the brand of ignition coil being paramount to success.
Can someone that has had this problem advise me of their experience??
Thanks,
Brian P
89 IROC-Z 355
Old Jun 9, 2002 | 12:41 PM
Sena'sIROC's Avatar
BTT
Thanks,
Brian P
Old Jun 9, 2002 | 06:31 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The absolute best ignition module is the FACTORT one (AC Delco).
All the rest will leave you at the side of the road. I have tried Accel, Holley and MANY parts store pass-off's.
Old Jun 9, 2002 | 08:35 PM
Sena'sIROC's Avatar
The AC Delco is my problem, unless there is something else going on that I am not aware of. I have successfully toasted 3 of them with nothing more than my Accel Supercoil on the car.
I know that it is a heat problem under the cap that we have with our cars and it seems that just about everyone at some point in time has had to deal with a ignition module that kept blowing up on them.
I think it is time to face the music, if you don't have the problem now, eventually you will.
There are a couple of solutions -proposed- as they may be,
1. Explore the possibility that the ignition control module be of the same brand/make of the ignition coil; be it Accel, Holley, MSD, etc.
2. Pursue alternate means of cooling the ICM. The following links are a excellent idea of one person's pursuit and according to him, he toasted 3 ICMs, one of which were accel's, after which he added this and he didn't toast another one.
A Pentium II Heatsink used on distributor for increased cooling of ICM
A closer look of heatsink
Overall look of Heatsink on Dizzy
3. Relocate the ICM altogether to keep it away from under cap torture.
Any other ideas out there?? I'd love to hear them.
Thanks,
Brian P
89 IROC-Z 355
Old Jun 9, 2002 | 10:41 PM
89ProchargedROC's Avatar
i'm pretty sure if you are having a problem with the module there is a way to bypass and have your ignition box run it i believe
Old Jun 10, 2002 | 12:15 PM
Sena'sIROC's Avatar
I don't think that is a possibility with the 89 is it??
If so, can someone confirm/deny that??
Thanks,
Brian P
89 IROC-Z 355
Old Jun 10, 2002 | 12:35 PM
burnoutrpm's Avatar
the msd should replace the module altogether
Old Jun 10, 2002 | 01:06 PM
Thanks,
Brian P
89 IROC-Z 355
You "can" do it
look through summit, they offer a wiring harness and how to bypass the module and just use the box as the module
Old Jun 10, 2002 | 03:03 PM
Sena'sIROC's Avatar
I just talked to Summit Racing and they told me that it could be done on the Big HEI distributor but it wasn't possible on the small cap HEI.
No dice.
Can anyone give a definite solution as to prevent smoking these modules??
Thanks,
Brian P
89 IROC-Z 355
Old Jun 10, 2002 | 04:57 PM
Sena'sIROC's Avatar
Is there anyone that might be able to help before I go to class in a few minutes and try to fix the car?
Thanks,
Brian P
89 IROC-Z 355
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
