how do i set/adjust my timing?
Old Mar 29, 2005 | 11:09 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
my distributor gear and timing light should be here tomorrow, but i've never timed a motor or seen one timed. how do i do it, and whats a good starting point?
Old Mar 30, 2005 | 04:58 AM
ede's Avatar
ede
unplug the vacuum advance, est, or what ever you need to do to set base timing. attach the light per the instructions. point it at the timing tab and pull the trigger. move the distributor till the dampner mark matches the timing mark on the tab. if you have an advance light you'd want around 34-36* total, base should be around 6-10*
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
