fitting size
Old Mar 30, 2005 | 06:14 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
fitting size
i am looking for barb fittings that will screw into my radiator and th350 tranny until i get my lines done. i just wanna make some temporary lines for a week or so. i have tried 1/4 npt and they are too big, looks like i need an inverted flare fitting of some sort. tia
Old Mar 31, 2005 | 04:46 AM
ede's Avatar
ede
it's a flare, 5/16 i think
Old Mar 31, 2005 | 12:12 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
5/16" is 1/16" larger than a 1/4", I've never seen a 3/16" so it's probably a 1/8"npt.
Old Mar 31, 2005 | 12:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is not NPT.
It's 5/16" inverted flare.
Flare fittings aren't measured by the thread size (any more than pipe ones are); they're measured by the tubing size.
The transmission has ¼" NPT IIRC, with a brass adapter in it to hook the 5/16" inverted flare lines to. The same adapter would work at both the radiator and the transmission.
You can buy 5/16" brake line at the parts store, and make up your lines. Personally I wouldn't go through the hassle of the rubber crap, only to have to go back and do it AGAIN except right another time. The rubber garbage is going to be about ¾ as much work as doing it right. Not a whole lot of time or trouble savings.
Old Mar 31, 2005 | 04:23 PM
bubbz89's Avatar
Car: 1990 RS
thanks guys, i am getting some made at carquest, and they wont get my fittings in till next week so i am dead in the water until then. i just needed a temp solution for a week or so. thanks again!!!
Old Mar 31, 2005 | 05:48 PM
ede's Avatar
ede
you don't know much about pipe threads do you? do a little search on them and learn a bit more, it may serve you i nthe future.
Old Mar 31, 2005 | 09:44 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Fitting Size
Obviously I don't know as much as you do.
Why did you single me out to ridicule? Never mind, no sense in asking you why.
don't PM me i don't explain what or why i do anything
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
tom1985
Apr 19, 2016 07:55 AM
toronto formula
Nov 10, 2015 06:17 AM
wruiz
Aug 13, 2015 09:07 PM
knight72
Aug 10, 2015 09:32 PM
