idle fluctuation
Old Mar 31, 2005 | 09:51 AM
mustbeatmopar's Avatar
Car: 1991 pontiac GTA, and a1992 pontiac firebird
Engine: 5.7 l98, and a 3.1 for now
Transmission: 700-r4s
idle fluctuation
i have been haveing some trouble with the idle on my car. when i startit the rpms go from 500- 2500 repeatedly, it only does this in park and nuteral, i changed the o2 sensor but it just made it worse, now the car almost dies when the rpms bottom out at 500, could it be the throttle positioning sensor? is my engine destine for the junk tard? i need some help here, i am sick of changing parts for no reason.
Old Mar 31, 2005 | 11:59 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Welcome aboard!
Is this only a problem at idle? How does the engine run under load? Have you checked the egr to see if its blocked open? Any air leaks in the ducting leading from the MAF?
It could be a possible problem with the IAC, but those sort of fluctuations are a bit severe even for that.
Old Mar 31, 2005 | 08:55 PM
Coult_91's Avatar
Car: 91firebird, 2000 camaro
Engine: 305 tbi,K&N, edelbrock intake & 3.8
FIND THE 3800 ENGINE ALready......what else can i do for you
Old Apr 1, 2005 | 05:46 PM
the car runs fine once it is in gear but it does start to idle rough when i come to a stop.
Old Apr 8, 2005 | 07:27 PM
Coult_91's Avatar
posted for mustbeatmopar:
i looked at my manual and... i dont have a mass air flow sensor, and my egr valve is digital, meaning those two ideas are out the window. i am in trouble arnt I?
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
