HOT CAM ?
Old Jul 26, 2001 | 01:21 AM
SCFORMULA1's Avatar
HOT CAM ?
I just got a LT4 hot cam in my car, i also got new push rods (the crane ones for 88-97 chevy with hydralic roller cam execpt LT1 sence my car is a TPI )I was wonder sence its a LT1 cam would I need different push rods??
thanks
Scott
Old Jul 26, 2001 | 01:40 AM
Dan87IROC-Z's Avatar
I used the stock pushrods with my LT4 HOT Cam, I did use the stock lifters though.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, LPE High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Jul 26, 2001 | 02:09 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You can reuse the stock pushrods and lifters as long as they're in good shape.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
angel2794
Sep 8, 2015 06:22 PM
86iroczwv
Sep 3, 2015 06:21 PM
f-bodyz28
Sep 2, 2015 05:03 PM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
