Why do my emissions change so much?
Old Jul 25, 2001 | 01:23 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
While on the emission dyno, my results change drasticly between tests. My first run on HC was 12.00, second was 7.10, third was 2.96, and my fourth was 9.43. Why is it so different every run? I did a full tune up after the second run and i did nothing different between the third and fourth run. My limit BTW is 1.4 for HC. The rest of the tests stay the same for every run. I really need to get plates on my bird.
Old Jul 25, 2001 | 09:29 AM
iroc5speed's Avatar
this might have been due to the changing temperatures of your car. running a car hot will lower your emmisions
Old Jul 26, 2001 | 03:44 AM
EvilCartman's Avatar
Car: '82 Z28
Heating up the cat good will make it run cleaner... Might want to check your timing to lower those numbers. Saw a truck today that pegged the smog machine cause it was too far advanced. Back to stock timing the HC went way down.
InfinityShade
Feb 21, 2016 01:29 PM
billybob6110
Feb 11, 2016 10:41 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
BAMiller
Sep 14, 2015 06:38 PM
theurge
Aug 21, 2015 12:46 PM
