Starter Installation
Old Jul 25, 2001 | 08:02 PM
N3ZNF's Avatar
Car: 89' Chevy IROC
Engine: L98 350
Hello,
I managed to get the old starter removed. Actually once you figure out the trick its not too hard. Now I cant seem to flip the new one in, once I get it in it seems to be about 180 degrees off. Whats the trick? Should I try spinning it clockwise or counterclockwise? Id remove the solenoid but thats not an option. Any advice is appreciated, I quit for the evening, tired and hungry.
Whats the procedure for shimming, should i first try it then take the jackstands out and start it on the ground or can I start it while its on the stands (doesnt seem like a good idea but might as well ask)?
Martin
Old Jul 25, 2001 | 08:39 PM
rezinn's Avatar
You need to put it in so that the starter is facing the right direction, iirc..try putting it in with the starter facing down and the solenoid facing you, and then spin it to the right when it is through so the starter will bolt on correctly. It feels like it will never work, but it does eventually.
If you didn't need shims before, you probably shouldn't now. Starting it on jackstands won't make any difference, since the starter is bolted to the engine.
Old Jul 26, 2001 | 09:20 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
If all else fails, remove the solenoid and install the starter, then reattach the solenoid.
Old Jul 26, 2001 | 09:31 AM
N3ZNF's Avatar
Car: 89' Chevy IROC
Engine: L98 350
Thanks!
I got it in. The trick is to face the solenoid (connections) up, and slide them in first, its the opposite the way u think, then u have to spin it just right and itll slide into place. I hope this helps someone else.
Thanks Again
Martin
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
milk
Aug 10, 2015 06:26 PM
