timing?
Old Jul 26, 2001 | 07:08 PM
Matt's Avatar
timing?
Ok installed new dist. but wont go in the same as the old. there is a mark on the balancer, do i align this with the 0 mark on the timing tab or what? thanks for the help
Matt
1984 Trans Am
89 GTA interior, 95 seats, Eibach springs, KYB shocks and struts, Hurst shifter, K&N filters, removed cat, ******* cherybomb exhaust
Old Jul 26, 2001 | 07:30 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
With the #1 cylinder on the comrpression stroke (remove the plug and feel for air coming out the plug hole) Then put the engraved mark of the balancer in line w/ 0* on the timing tab. Now drop the distributer in and put the cap on and note where the #1 plug wire goes on the cap. Pull the cap off, and if the rotor isn't pointing to where the #1 on the cap is, you will need to pull the dist and turn accordingly.
The hardest part is getting the rotor lined up properly along w/ the oil pump drivesahft. The distributer will not fully seat unless the oil pump driveshaft is lined up. It splines w/ the bottom of the distributer and you will have to take a long screwdriver and turn it so it lines up.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
