Using vortec heads on 350 come in here.
Old Apr 1, 2005 | 06:08 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Hey i want to see your set ups with the vortec heads. I almost have everything together for my build using the vortecs going carbureted. Things i want to know are, what cam are you using. If you had the heads machined for instance the guides . What springs did you go with. I'm not sure how much o.d of a spring i can go with.
Old Apr 1, 2005 | 07:18 PM
Car: 2002 SS
Engine: Ls1
Old Apr 1, 2005 | 11:47 PM
Car: 2002 SS
Engine: Ls1
Will 1.530 O.D valve springs fit on these Vortec Heads with machining.
Old Apr 2, 2005 | 12:18 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I have no idea what specs my heads are machined to... but I am cool.
Old Apr 2, 2005 | 09:50 AM
Car: 2002 SS
Engine: Ls1
that was very usefull information thank you so much.
Old Apr 2, 2005 | 11:18 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Chevy Hipo used these springs on there 350/330hp upgrade project. CCA-26918-16 valve springs, single beehive, 1.055 in. outside diameter, LT4 Hot cam and 1.6 RR produced 400hp on a dyno. I will post the article if I find it again.
EDIT: Sorry it was carcraft here is article. http://www.carcraft.com/projectbuild/116_0403_mail/
Old Apr 2, 2005 | 11:38 AM
Car: 2002 SS
Engine: Ls1
that springs open load is too small i just looked it up.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
