Piston Questions
Old Jul 27, 2001 | 10:46 AM
icenine9's Avatar
Piston Questions
Is it better to go with a bushed pin or a pressed pin? The Speed Pro Forged pistons are going into a 400hp 350. Can i put the pins in myself, or should i have a machine shop do it?
If i was to rebuild an engine, can i let it sit for a few years with the assembly lube before i put it in my camaro?
[This message has been edited by icenine9 (edited July 27, 2001).]
Old Jul 27, 2001 | 12:25 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
you need to have the shop press the pins into your pistons (he'll need the rods as well) because he will be using a small oven to heat up the piston, and I don't think you have an oven that goes that hot
Webmaster: www.IROC-Z.org & www.GMPerformance.org
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
