Code 32 while cruising at 70mph
Old Jul 22, 2001 | 07:33 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I had some problems last summer with the IROC tripping a code 32. I had some hard starting issues also that might have tripped the code. I replaced the EGR valve and all was good. Even last summer and again this summer, I have been getting the code 32 only when cruising around 70 for about 15 minutes or so. I don't have problems if the speeds fluctuate. What could be the problem? The car has only 8300 miles. If it might be vacuum related, can someone show me what vacuum lines might need replacing?
87 IROC 350 TPI with less than 10k original miles
93 Z28 Pace Car #494 of 645
86 Olds 442 (All Original)
My IROC Website
Northstar Camaro Club of Minnesota
Old Jul 22, 2001 | 10:00 PM
Vader's Avatar
SM,
Recheck the EGR and EGR diagnostic temperature sensor. A little carbon on the sensor valve makes a nice restriction and insulator.
The vacuum routing should be something like this:
Check the nylon tubing under the plenum and from the EGR solenoid to the valve.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jul 25, 2001 | 07:27 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
My 90 formula 350 does the same thing. Where is that sensor? I see it in the picture but where did it come from? Don't see it on my engine.
Old Jul 25, 2001 | 10:50 PM
scottmoyer's Avatar
The sensor screws into the base of the EGR valve. You might not see it cuz it's under the plenum.
My IROC Website
Old Jul 26, 2001 | 11:38 AM
Pino91Formula's Avatar
Not all egr's have the sesor either , I had the same problem over the winter , My problem was solved after three erg valves a vacume soilnoid and new vacume lines,, what was causing my problem was my exhuast being to free flowing, the egr in my car is a negative feedback valve wich works with back preassure from the exhuast, . so i tested this theary by putting on a 20 dollar special mufflar , I havent had a problem since.
Old Jul 27, 2001 | 01:22 PM
Car: 1984 Z28
Engine: 454
Transmission: Th400
Think i'll just quit driving 70mph with the cruise on.
wigmobile
Feb 26, 2025 02:56 PM
dmccain
South East Region
Sep 30, 2016 06:23 AM
BumpaD82
Feb 26, 2016 02:57 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
ULTM8Z
Sep 16, 2015 09:15 AM
