pulling engine with wire harness
Old Apr 2, 2005 | 08:08 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
can i pull the engine out with the wiring harness?? if so what part of the harness do i disconned besides the part behind the fender
Old Apr 2, 2005 | 08:53 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
I guess you can, but why? There are two harnesses in the engine compartment, one for the motor and one for other electrical stuff (alt, headlights,etc). The second one connects under the brake booster on the firewall. The problem is that some of the wiring is mixed together and you might have more of a problem figuring out what goes out with the engine and what stays under the hood. I would take pictures and use masking tape to make labels of what went where.
Old Apr 3, 2005 | 05:04 AM
ede's Avatar
ede
sure you can but why would you want to. it's increase the amount of work you'd need to do by at least 2 times a nd putting it back in would be much worse.
Old Apr 3, 2005 | 06:37 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
that sound wierd....i was trying to save work.... its a car thats being parted out i have a 92 rs 305 tbi im transplantting into a 87 trans am that has a 305tpi in it so i have to remove the wire harness... well whats left of it anyway... and put the rs one in there ...
Old Apr 3, 2005 | 11:07 AM
ede's Avatar
ede
if all you're doing is parting it out and want the engine all you need is a pair of side cutters to get around the harness.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
