HELP, steering shaft and ECM problems. SLP is too much...
Old Jul 27, 2001 | 05:47 PM
82resto's Avatar
Ok, I just got done getting my 1 3/4 SLP headers in my car, bolted on, and exhaust all done. Now I have two problems. #1, the steering shaft rubs the header. I should've listened to everyone's complaints. #2 I took the AIR system and smog pump off, and there was a plug going to the intake manifold (a gm weather pack type plug) from the canister where all the AIR hoses met (EGR maybe?). Is that plug necessary? My car runs fine without it plugged in, but i'm just curious as to what it did. Anyway, the steering shaft is a serious problem. Any help?
Jon
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
Old Jul 27, 2001 | 07:11 PM
james_fearn's Avatar
from inside the vehicle loosen the bolts to the steering column and move the steering column over. It may take some work to get to them, maybe not.
The fitting is probably for the EGR tempo sensor. All the sensors have plugs for them except the one in the radiator that is there but no wires go to it.
James
1985 Z-28, 350 TPI, T-Tops, edelbrock 6085 heads, ZZ4 cam, accel base/runners & 24 lb/hr inj., ported plenum, everything gasket matched, crane AFPR, SLP 1 5/8 headers, single 3" flowmaster catback, 3" Catco cat, modified tranny, 165 ECM & ARAP code, MSD 6AL/wires, edelbrock STB, Spohn SFC, GW "wonderbar"
Old Jul 27, 2001 | 07:16 PM
aquila's Avatar
At the bottom of your steering column inside the car there is several bolts that hold the column to the firewall. Take the bolts out and the nuts at the top of the column to the dash. Use a dremel tool to open the holes to the right of the firewall plate, about 1/4 inch is the most you will get. That should be enough to clear your headers. I have 1 5/8th SLP headers and all I had to do was loosen the bolts and take up the slack to have enough clearance. It is a pain but I'm very happy with my set.
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Oct 3, 2015 12:43 PM
SG91camaro
Sep 5, 2015 10:27 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
