Anti freeze leaking?
Old Apr 3, 2005 | 06:58 PM
Megaracerx2's Avatar
On Probation
Car: 1986 Trans Am
ok,
i pulled into my driveway yesterday, and i noticed a little bit of steam coming from under the hood....opened it, and the was antifreeze evrywhere...i look under the car...and its literaly pouring out....i though the hose had a leak....replaced that....and started it up...nothing changed...still leaking like crazy...
maybe the water pump burned up? thats my only thought....
Old Apr 3, 2005 | 07:24 PM
Steve86TA's Avatar
Car: To many to list
is it leaking from the water pump area or the radiator area or somewhere else?
Old Apr 3, 2005 | 07:25 PM
On Probation
Car: 1986 Trans Am
leaking from the water pump area as far as i can see, but it deffinatly not coming from the radiator.
Old Apr 3, 2005 | 07:41 PM
jokers's Avatar
Car: 86firebird/86 trans am
Engine: 2.8ho/305HO 4BB
Transmission: WC T-5/700R4
resonce to your leak problem
sounds like your leaking from the weep hole in your water pump. check to see if that's where it is comming from. it's the little hole generally on the bottom side of shaft where the pully is conected to. this is pretty normal.
Old Apr 3, 2005 | 07:42 PM
On Probation
Car: 1986 Trans Am
thats what i was thinking...but its an LG4 so...its a PITA to get to anything
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
