Best Way to Install Extra O2 Bung?
Old Apr 4, 2005 | 09:10 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I bought an extra bung to weld in for a wideband sensor. Should I drill the hole first and weld the bung on over it or should I weld the bung on first and try drilling the hole after and risk hitting the threads with the bit?
Old Apr 4, 2005 | 09:38 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
drill the hole
scrape/grind the metal around the hole for a good weld
weld the bung on, centered over the hole.
Old Apr 4, 2005 | 09:39 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
btw, last time i did it i stuck a piece of metal rod thru the bung, into the hole.
that held it centered, and it protected the threads from welding splatter....
firebirdjosh
Nov 14, 2005 11:06 AM
Markolc
Nov 2, 2001 07:53 PM
Markolc
Oct 31, 2001 12:59 PM
