Should I install another O2 bung for tuning?
Old Nov 12, 2005 | 07:30 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm doing my exhaust right now and adding an oxygen sensor bung would be too hard at the moment (exhaust system is all off the car). I'm going to have it tuned or learn to do tuning in the future, would installing another O2 bung be a wise idea? Like is that with a wideband O2 sensor the best/easiest way to get an accurate tuning.
Old Nov 12, 2005 | 08:56 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I believe it is a good idea. Dyno Don installed another O2 bung on my exhaust so that we could run a wide band O2 sensor during the tuning phase.
Old Nov 12, 2005 | 09:41 PM
Car: 86 T/A
Engine: HSR 355
I figure for $8 I can't go wrong, especially for 30 seconds of labor while the pipes are off. I just didn't know if shops use wideband 02 sensors or what.
Old Nov 12, 2005 | 10:32 PM
Car: 1989 GTA
Engine: 369 TPI
Right, for the money you can't go wrong. Your car needs the NB O2 sensor to run then the other bung can be used for the WB O2 sensor for tuning at the same time.
Old Nov 12, 2005 | 10:45 PM
Car: 86 T/A
Engine: HSR 355
Very much appreciated. Thanks!
Old Nov 14, 2005 | 11:06 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
A couple of things to keep in mind when installing the O2 bung.
If the pipes are off the car, you will need to re-install them (at least partially) to see where you can fit the extra O2 sensor. I had a little trouble trying to find a good spot. You will want the sensor mounted so condensation will run out of it and into the pipe. If there's any water inside the sensor and power is applied to the o2 sensors' heater, you'll be looking at buying another wide-band o2 sensor($$$).
I wound-up mounting mine abt 12" fwd of the cat.
Had to massage the passenger floor board a bit to get the sensor installed.
Oh yeah, one more thing. Have an old sensor or a plug screwed into the bung while it's being welded. That will keep the threads clear of any slag from the welding process. Learned that one the hard way!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
BLK87Z
Sep 18, 2015 11:29 PM
