electronic vss question
Old Apr 4, 2005 | 06:56 PM
kamu's Avatar
Car: 84 Z28
Engine: 400
Transmission: tex racing t101a
Axle/Gears: 4.56
I have a 86 trans-am with a digital speedometer in it. I have a 700r4 for it that has a cable driven speedometer in it. What year VSS will fit this car so all I have to do is plug in the speedometer wire. I realize that I may have to change the drive gear on the tranny this is not a problem. I bought the car as a roller so I do not have the original tranny. The guy I bought it from said all I have to do is get a VSS for it. I have 3.73 gear ratio. Any links on where I can buy the needed stuff would be great.
Old Apr 4, 2005 | 09:48 PM
Vader's Avatar
A VSS from an '86 should work fine. The key will be in getting the correct plastic driven gear on the VSS for the rear gearing. The dealer should be able to help select the right gear.
Old Apr 5, 2005 | 02:11 PM
kamu's Avatar
Car: 84 Z28
Engine: 400
Axle/Gears: 4.56
Thanks for the help
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
