What RPM should my car Idle at??
Old Jul 27, 2001 | 06:11 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hi Guys, what RPM should an 89 5.7 GTA with TPI idle at in park, and in drive? And in park with the AC on and in drive with the AC on? Just curious on this. All I have is the owners manual that came with the car, and I don't see it in there.
Mike
(Gran Turismo Americano) "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber).
Old Jul 27, 2001 | 07:28 PM
Enkil's Avatar
The car should idle in drive around 750rpm.. Park/neutral doesn't matter. AC doesn't matter either really, so long as it doesn't stall. If the idle in drive is fine, all will follow. heh. There's technical articles on how to set this.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jul 27, 2001 | 07:42 PM
breathment's Avatar
mine idles at about 500, but its also kinda rough.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Jul 27, 2001 | 08:14 PM
Engine: ZZ4 - 350
Mine seems to Idle in drive at about 600 & 700 in park. It s real smooth. I was just curious what the factory Idle was. But as long as it is running good, and not idling too high it is alright. I tuned the car up today, I thought it was running good before the tune up, but man it idles so much better now. If it wasn't for the noise from the flowmaster, you wouldn't even know it was running.
Thanks for the info guys!
Later
Mike
Old Jul 27, 2001 | 08:47 PM
reborn's Avatar
Mines idling rough at 500 or just under and the tag under the hood says it should be 600.
Anyone got or know of a good set of instructions for adjusting idling speed for an 84 L69 5.0 4bbl HO??
thanks
Old Jul 27, 2001 | 10:04 PM
rezinn's Avatar
My 87 305 tpi idles smoothly at 500rpm.
Old Jul 27, 2001 | 10:51 PM
One Eyed Jack's Avatar
my 305 TBI idles at 600 now with my new O2 sensor
1992 Pontiac Firebird
- 305ci V8 TBI / Automatic Trans / Loaded
- MODS: Edelbrock 14x3 Open Element Air Cleaner, Dual outlet exhaust
1985 Chevy Z28
- 350ci V8 TPI / Automatic Trans / Paid $200 for it
- In the process of restoration!
Old Jul 28, 2001 | 09:33 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
All the idle speed is controlled within the ECM. At normal operating temperatures, the idle when in Drive will be around 600 rpm. If you have a colder T-stat, the temperature will be higher because the engine thinks it is still in "cold start up" mode. This is one of the tables you need to adjust if you go to a colder T-stat.
Also, in Park/Neutral, the ECM will add another 100 rpm and 25 rpm for the AC. All of these parameters can be changed in the ECM. I personally lowered the amount of RPMs to add in P/N to only 50 additional RPM. Makes for a much smoother transition when moving the gear selector and it's much easier on the drivetrain.
When the coolant temperature is below 195*C, there are various "desired RPM" to assist in "cold starting". This is why a colder T-stat like a 160* causes your car to idle higher (around 750 rpm in Drive, +100 P/N, +25 AC; IIRC).
This is if your IAC and TPS are in proper working order and set correctly. People trying to "adjust" their TPS/IAC, especially for this "greater than 4.5 volts to get into WOT sooner BS" generally screw things up and can result in an erratic idle.
Old Jul 28, 2001 | 02:58 PM
Engine: ZZ4 - 350
Thanks or the advice everyone. I think I am right on the money with my Idle Glen91L98GTA. Thanks man
Later
Mike
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
killer777
Aug 8, 2015 02:47 PM
