What do sounds sound like?????????????
Old Jul 28, 2001 | 08:04 PM
89project's Avatar
I read about cluncks, that seems to be an easy one. But what does an ENGINE KNOCK sound like. I'm having a brain fart right now but there are others that are writen but IF you have any sounds that you can explain it would help me out a lot.
ON a side note. My engine makes this kind of pfft-pfft-pfft. . . sound when I accelerate hard. If anyone can explain this I would appreciate it. I have an 89 IROC 350 TPI, rebuild last fall, otherwise stock, headers, new plugs-wires-cap-rotor-coil within the past month. Don't think was there right after that, but got rear ended a couple weeks ago and his car was forced between the bumper and tail pipes, and seems to be gettting louder since then, at least that I can remember, but could be imagining it. Oh and I only have about 2,000 miles since the rebuild.
Old Jul 28, 2001 | 08:08 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
I know that I am not much help man, but it could be part of your emission's system, Leaking air.
Later
Mike
(Gran Turismo Americano) "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber).
Old Jul 28, 2001 | 08:22 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Your pft-pft-pft sounds like a header gasket. Look for signs of burning (black) of the header flange gasket. Also look at the collector gaskets.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
