Car won't start after new intake install, need help!
Old Jul 28, 2001 | 04:14 PM
Dan87IROC-Z's Avatar
I just got done installing my new Accel/LPE intake base, and now the damn thing wont start. When I pulled out the distributor, I marked the rotor to distributor base location and marked on the distributor base where it lines up with the intake. I put it in in the same position I took it out and now it won't start. So this morning I took it out, flipped it 180* and it still won't start, I have no clue what is going on. Does anyone have ANY ideas, it might not even be the distributor, I don't know. I just need help!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, LPE High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Jul 29, 2001 | 01:48 AM
89 CamaroIROCZ's Avatar
I say timing is the issue. If thats off it might not start. Also, make sure you hooked up all your connections (very important) and you don't have any EXTREMELY bad vacuum leaks. Next try to make sure you have spark if everything else is fine. There really isn't anything else that could be wrong at that point so keep checking.
Matt
89 Camaro IROC
350" GM Crate Motor
Crane Cam 234/242 .473"/.488"
Edelbrock Torker II Intake Manifold
Holley 650 DP
Hedman Headers
Dynomax Exhaust Minus Cat
B&M Holeshot 3000 Lockup Converter
Old Jul 29, 2001 | 01:59 AM
BenDoe's Avatar
It could possibly be the ECM. Make sure when you turn the key to the on position, the check engine light comes on. If it doesn't, you might have blown the fuse to the ECM. Another thing to do is to make sure you have a spark, and make sure the car isn't flooded.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218, 187 head castings with bigger valves, self-burned eproms.
Gained 20HP by porting and polishing my EGR passage.(some people take this seriously)
All work done by myself, and proud of it!
Find a .bin on the internet and want it burned? I'll do it for you!
Old Jul 29, 2001 | 02:18 AM
Well, I think I might have pin-pointed the problem, thanks for opening my eyes guys! For being such a car enthusisast, I can be moron sometimes, lol.
L98 TPI 350 (5.7L)
Old Jul 29, 2001 | 02:40 AM
BenDoe's Avatar
what was it?
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
killer777
Aug 8, 2015 02:47 PM
mustangman65_79
Aug 8, 2015 12:07 PM
