Unfamiliar component wants a engine drive belt
I got an '84 305, facing the car from the front and looking down the front of the engine theres something that wants a drive belt on the bottom left of the engine.
What is it? And has the car been trashed by it not being hooked up??
I just noticed it the other day and went to get a belt for it but I didnt know what it was called. The guy at the auto store tried selling me one of every belt in the car and told me to try till one fits. I dont have the money or the time to mess with that crap.
So any ideas?? (car has AC btw)
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
It's called an air pump it's job is to pump air into the exaust(sp?) system and reduce emissions. I'm not sure but you mite be hurting the cat by not having it hooked up.
Car: Take
Engine: Your
Transmission: Pick
Sounds like the smog pump. The belt was probably taken off for a reason, I bet its noisy as ever. No ill effects done w/ it unhooked, unless your a tree hugger.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 11, 2015 10:11 PM
