timing
Old Jul 28, 2001 | 01:44 AM
SCFORMULA1's Avatar
timing
I know this a dumb question but I was just wondering where the dots on the timing chain line up at when #1 is on top dead center on its compersion stroke, are they facing each other or what? Also where does the distributor point at (what piston should be firing) thanks for any help
Scott 89 305 TPI Formula
Old Jul 28, 2001 | 04:26 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
timing marks with the motor #1 cylinder top dead center are both at the top..
#6 cylinder TDC is cam sprocket dot down, crank sprocket dot up..
here's a FAQ on installing your distributor correctly, email me at admin@IROC-Z.org if yo'ud like some clarification
http://www.iroc-z.org/tech/distribut...ngdistrib.html
Webmaster: www.IROC-Z.org & www.GMPerformance.org
Old Jul 29, 2001 | 11:21 PM
SCFORMULA1's Avatar
thanks
Scott
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
