Mobil 1 oil
Car: 91 formula
Engine: 350 tuned port. bolt ons
Mobil 1 oil
I have a 87 350tpi and it burns a little oil. I was wondering if i put in mobil 1 15w50 will it be to thick. does anyone run this oil and how is it.
Transmission: 4L80E/4L80E
I'm going to nip this one in the bud. Oil threads turn into opinion journals and flame fests.
15W-50 is thicker than necessary for use in the typical factory-spec, street driven vehicle. If you have an oil consumption issue, fix the problem. Thicker oil isn't going to do much.
10:1 with a factory SBC, you've got hardened, cracked valve stem seals. Replace them with a more positive sealing type, and you'll solve the oil consumption problem without any crutches.
For general oil information or Mobil 1 or synthetics in general, do a
For valve stem seal replacement information,
.For valve stem seal replacement information,
. Thread
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
[PA] Stock 91 z28 springs
Orr89RocZ
Sep 13, 2015 09:41 PM
