Wear life on alluminum roller rockers?
Old Jul 30, 2001 | 04:25 PM
LottaBallsCamaro's Avatar
I was reading that they all have a problem with the bearings wearing out fast. Also it said the alluminum will become stressed and break or something? I figured someone would buy roller rockers for improved wear life but whats the point if the $300 set of rockers give out anyway?
I'd rather be historically accurate than politically correct!
Old Jul 30, 2001 | 04:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
AFAIK there's nothing inherent in their bearings that makes them wear out fast.
Aluminum fails by way of "fatigue". What happens is that after a certain number if stress cycles, the metal suddenly will just break. It usually gives little or no warning. This characteristic of aluminum is why airplanes have such a rigorous inspection and replacement cycle based on hours of operation and landings.
They were originally meant for racing. Even in the most extreme sort of endurance racing, they only have to last 24 hours or so. On the street, at 50 mph average, 100,000 miles is 2000 hours of operation. Big difference in how you go about designing for "improved wear life". They won't wear out in 24 hours, and they'll withstand a helluva lot more punishment than stock sheet-metal ones; but they don't have lifetimes in the thousands of hours.
A good compromise is the Comp steel ones. They're lighter than aluminum, because they don't have to be so huge to combat the "fatigue" problem (steel doesn't fail that same way), they're usually narrower so they fit better under stock valve covers, and they will go thousands of hours (hundreds of millions of stress cycles)between failures.
ICON Motorsports
Old Jul 30, 2001 | 04:43 PM
RW91B4C's Avatar
No, Crane sells good quility roller rockers for around $160 in JEGS, and these things will not break or wear out. The only two way i can think of would be, high rpm with a big solid roller and alot of spring pressure, or other bad valvetrain geometry problems. But you would bend a push rod first, before breaking a rocker. The $300 ones are real good quility and can be run for hours at high rpm like 8000 to 9000 rpm, like nascar engines, so for a street engine its overkill anyway. Hope that helps
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
TexasMaro
Sep 15, 2015 06:50 PM
