Do I need to swap fuel lines?
Old Apr 9, 2005 | 01:04 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Right now I have a stock 1982 Trans Am with a Q-jet and a mechanical fuel pump. I was just told that the mechanical fuel pump has a return line. It has all of the emissions equipment(sans air pump). I'm planning on switching to an 86 TPI system. Do I need new fuel lines? I know the lines come up to the passenger side of the engine block. Where do the lines for a tpi go to?
Old Apr 9, 2005 | 12:20 PM
sellmanb's Avatar
Car: '86 Berlinetta
The block mounted fuel pump will no longer be neccessary. Buy a block-off plate for the fuel pump and throw the old one away or sell it or something.
The TPI system uses a fuel pump in the fuel tank. You can also just add a sump in the tank, and have the fuel pump be outside of the tank (useful if the fuel pump craps out at a later date!).
I havent done the TPI swap, so that's all that I can be of help on. Good luck!
Old Apr 10, 2005 | 07:11 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I just noticed that the fuel lines are on the drivers side for a tpi. I don't know if I'll need an entire fuel line setup or just part of it. Anyone know?
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
