How can I hook up a fuel pressure?
Old Apr 10, 2005 | 08:04 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
My car was hesistating from time to time on the track, the rpms dropped quite a bit one run. How can I hook up a fuel pressure gauge to find out how much pressure I have?
The car is a stock 1982 Trans Am, LG4, Q-jet, with a mechanical fuel pump.
Old Apr 10, 2005 | 08:27 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
you can put a fuel pressure gauge on your shrader valve located on your passenger side fuel rail
Old Apr 10, 2005 | 08:57 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: How can I hook up a fuel pressure?
Hook it up to what kind of engine?
Old Apr 11, 2005 | 12:11 AM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Whoops, guess that's kind of important. It's a stock 82 LG4, Q-jet, mechanical fuel pump. Because it doesn't hesitate all the time, I was thinking the heat from the headers(which are ceramic coated) could be boiling some fuel in the lines. But, I'd still like to find out if the fuel pump is working properly.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
