How long should fuel preassure remain after shutdown?
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
My fuel preassure is holding about 38 psi after shutdown for about 30mins then it slowly blleds off. I know its not injectors cause I have no trouble starting and I had pulled the whole rail and theres no leaks. Could it be dropping through the pump. Could this ber a reason my pump screams incredibly loud after about 45 minuts of running. You can here my pump down the street over my flowmaster exhaust. It getrs that loud
1987 T/A GTA 5.7L, Bored .020 and ported for .202 valves, edelbrock headers, flowmaster exhaust, JET STAGE II chip, Comp CAM, Adjustable fuel pressure, Airfoil, K&N filter, B&M stage 2 shift kit, and a home depot ram air(Hey it looks good and it works)
If you are holding pressure after 30 minutes, you should have no real problems. My '86 holds pressure for several days, but it has low mileage. Your regulator itself may be leaking back slightly, which isn't a huge problem. The check valves in the pump could also be leaking back, but if you make good pressure and hold it for 30 minutes, that isn't a real problem either. As for the noise, every pump I have sounds different, and the noise can change a lot with temperature. Unless you can no longer hear the stereo, noise is not a great diagnostic tool for fuel pumps. By the time you notice a big change, it will probably be too late anyway.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Later,
Vader
Ghettobird52
Jul 5, 2024 11:18 PM
