Easy Engine Identification
Old Jul 31, 2001 | 07:56 PM
john fin's Avatar
Is there an easy way to identify a 305 from other small block chevy v8's?
Old Jul 31, 2001 | 09:22 PM
camaroguy99's Avatar
nope, externaly they are the same block. The only way would be by the VIN # or if it's a TPI the color of the injectors, assuming they still have the stock injectors. You could take the crank out and verify it that way but thats not really easy is it?
Old Jul 31, 2001 | 10:14 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Casting numbers at the rear of the block on the drivers side, on the ledge at the bellhousing.
Some even have 5.0 or 5.7 cast into the block.
I have seen the casting numbers on the passenger side in the rear, but not often.
Take the number and post it here or go to www.mortec.com, they have them there.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited July 31, 2001).]
Jorlain
Aug 24, 2022 05:11 PM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
