whistle noise
Old Apr 11, 2005 | 08:49 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
whistle noise
I put a new alternator on and all of a sudden there was a whistle, everythign is on tight and the belt is tight... i was looking AT It tonight and a grey cylinder came off what is this?
Old Apr 11, 2005 | 09:09 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Post a pic of it ?
If its metal and has a slit in it , it might be a sleeve thats used to hold the bolt in place under the alternator.
Old Apr 11, 2005 | 09:37 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
no camera, its flat sivler like a cap, its metal and it has teeth on the inside of it
Old Apr 11, 2005 | 09:59 PM
robsgta's Avatar
I think it is the lock washer that holds the nut down that holds the return wire from the battery to the alternator.
Old Apr 12, 2005 | 06:55 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
is that a bad thing?
Old Apr 12, 2005 | 11:50 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Not as long as the screw deosn't get loose
I would also say it' a lock washer, but the word "cylinder" throws me.
Old Apr 12, 2005 | 06:21 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
i would take a picture of it if it wasnt laying on the highway some where... hard to explain... on the back oif thealternator there is like a hole.. it goes in there, it looks liek ther is a screw and lub. so i think it was like a dust catcher or kepper outer.. but the guy at autpzone said sinceit was new i dont need to worrie cux of warrenty. and he said that that wasnt causing the whistle
Old Apr 12, 2005 | 08:41 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Maybe a bad bearing in the alternator? I know when the bearings went in my Power Stearing pump it sounded like i had a small supercharger under the hood it would whine when i reved it up. I thought it was cool until the pump died on a curvey road.
Old Apr 12, 2005 | 09:08 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
it might be it looked kinda like somethign that spinned. yeah i love the sound lol, (street racing purposes) if i did or course... yeah ima exchange it this weekend
Old Apr 12, 2005 | 11:47 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I also have a whine. I went over the whole engine with a stethoscope. It is the loudest by the throttle body. Car runs perfect, I don't know what it could be. Ive had some people that heard it tell me it is just the air being sucked in from the intake.
Heres what mine sounds like.
Old Apr 17, 2005 | 06:40 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
i bought a new alternator and a new blet for the crank to powerer steering pump to something else the whislte is gone
Old Apr 17, 2005 | 09:04 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
My whine is from the alternator (new) with key on/engine off.
Old Apr 17, 2005 | 09:12 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Last year I installed a Powermaster 140amp altenator to replace the big bad 70amp altenator that was originally in my car. After installing it I got that same whistle/supercharger whine. My cars power system sits at about 14.2V with no problems. Do you notice a voltage drop after a long drive?
Old Apr 17, 2005 | 09:18 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Yes.
if the car sits for a couple of day(some times more) the volts is =>14 while charging.
Old Apr 17, 2005 | 10:14 PM
Car: 1988 IROC-Z
Engine: 427 SBC
I also found my whine, turns out it is the alt
Old Apr 18, 2005 | 05:31 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
look at the back of it and see if you can see inside it.. hard to expain. its where the pullt and stuff turns... if that cap in the back comes off you can get those noises;..... turn out that was mine... it fell off and it was grinding of the internals
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
