fuel rail and injector assembly questions
Old Aug 1, 2001 | 01:14 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Any tips or advice on how to reassemble all this injector stuff so that it won't leak? I assume I need new O-rings. Will any O-ring do, or do I have to get special ones for the fuel rails? I know they make special rings for the injectors.
91 Z28
Come see The Vicious...
Old Aug 1, 2001 | 02:59 PM
ede's Avatar
ede
you need the o rings (vitron) made for the rails, some cheaper o rings (buta rubber) won't stand up to gas. i use motor oil to lube the o ring so it goes in easy and doesn't get cut.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Andrew6.688
Dec 13, 2015 10:59 AM
Brcharrelson
Aug 26, 2015 07:47 PM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
