TPS problem
Old Aug 1, 2001 | 04:51 PM
DarkSideOfTheMoon's Avatar
TPS problem
I had a major problem with my TPS...car was trying to go when I was at a light . Needless to say, I replaced it and adjusted it properly per instructions on this site. However, under WOT I am getting an engine light after RPMs hit 3500 (or around there) and it stays on for about 3-5 seconds after I drop the WOT. I am getting and ECM code telling me I am running to high of voltage yet I am sure I am set right. Time for a new ECM? Short in the system somewhere? TIA
Rob Hamilton
Chicago IL
AIMrkside0fthemoon
85' Trans Am
Stock as hell...looking to change that
VIN#1G2FW87F6FL623877
Old Aug 1, 2001 | 05:04 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Try to reset the ECM. Then check what voltage range the TPS is operating in, If I remeber correct it should be 0,54-4,2 volts. correct me if I'm wrong..
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods, a Canfield headed 383 in the works!! ready May 2001...ok..june...july..and with Accel DFI....looking for SR or miniram....
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
92camaroJoe
Jul 29, 2023 07:57 PM
GTAman
Sep 21, 2015 09:57 AM
soarestransam
Aug 24, 2015 08:15 AM
92camaroJoe
Aug 13, 2015 06:07 AM
