Modifying intake for vortec heads?
Old Aug 1, 2001 | 12:01 AM
mcconahay37's Avatar
I wanted to know if I can modify my performer RPM intake to fit vortec heads by drilling the holes straight down to match the vortec heads. I did a little damage to my heads, and if it's going to cost almost as much as a set of vortecs, you can guess what I'm going to do. just keeping my options open. Thanks
82 Camaro:
350
Erson cam, ported heads,Comp Cams 1.6:1 rocker arms
Edelbrock Performer RPM intake, Holley 600
Crane Hi-6 ignition, Accel supercoil
TH350 tranny with 2500 stall.
Eibach Pro Kit
SLP 1 3/4" headers
Old Aug 1, 2001 | 12:15 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
The vortec heads only use 8 bolt holes to mount the intake for starters....not just the angle is different.
I belive the ports are a little off also.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited July 31, 2001).]
Old Aug 1, 2001 | 12:35 AM
tacoboy's Avatar
not sure if this is true but i heard today that you can get either the heads or a manifold predrilled to fit pre87 stuff....sorry i cant remember which it is...if its the heads (vortec), then thats you, if its the manifold then sorry
Old Aug 1, 2001 | 12:37 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Not feasible. Bolt holes aren't even in the right places. Ports would also be pretty badly mismatched. Only option is to get a new RPM that is made for Vortecs. Not too much money...
And it's the heads you can buy predrilled for regular style intakes, but you don't want those either. Like I said there are port mismatch problems with standard intakes (some intakes can't physically even cover the ports, much less match them for good flow...) And the Vortec's don't really have enough meat in the area where several of the new holes go. Only person I've known with these predrilled heads had problems with stripping the threads out pretty quickly. Scoggin Dickey prototyped doing this and refused to sell them due to the inherent problems. Do not go that route for anyone considering it. Just buy the damn regular heads and the intake made to fit em...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited July 31, 2001).]
Old Aug 1, 2001 | 05:33 PM
OK. That's what I needed to know. Thanks.
82 Camaro:
350
Eibach Pro Kit
SLP 1 3/4" headers
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
