Plugged passage on drivers side of block...L98
Old Apr 12, 2005 | 07:57 PM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
On the drivers side of the block of the L98 pretty much in the center there's a plug there in the middle of nowhere....anyone know what that is for?
I'm trying to find possible places for my autometer coolant temp. sensor....so I don't have to use a T-connector on the driver's side head with the existing sensor.
I can snap a pic of it if needed....
Thanks,
- Joel
Old Apr 12, 2005 | 08:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
By any chance is the knock sensor in the corresponding hole on the passenger side?
If so, that's the water jacket drain that's been in SBC's since 1955. It's a poor place to put a temp sensor since that's one of the coolest parts of the cooling system. In a head or intake water passage is much better.
Old Apr 12, 2005 | 08:10 PM
Engine: 6.3L - 383
Yeah...the knock sensor is in the coor. pass. side hole.
The coolant drain...thanks man....I've been wondering what that was for a while......
You're right....that would be a bad place for the sensor.....looks like I'll just pickup a T and throw it in the drivers side head along with the stock sensor. Thanks for the info! I'm gonna be dangerous soon with all the knowledge I've gained here LOL!
- Joel
Old Apr 17, 2005 | 10:06 AM
Vader's Avatar
In addition to being a cold spot, it's a poor position for a temperature sensor because most debris in the cooling system tends to accumulate there. This tends to insulate the sensor from accurate readings.
You can also drill/tap another hole in the opposite end of the head for an additional sensor, or drill/tap the coolant crossover of the intake.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
GVMV
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
