Radiator Cap
Car: 1985 IROC-Z
Engine: 305 Tuned Port Injection
Radiator Cap
I've read, with great interest all of the posts concering overheating. My car has done the overheating thing for the past few years. My mechanic has checked everything over and over again and as best as he can tell, everything is operating as it should. I've noticed that many times, it is suggested that the radiator cap be checked. #1, how do you do this, and #2, how would I tell if it is bad and needs to be replaced? It is the only thing I can think of that has not been replaced on my cooling system.
Car: 4
Engine: 6
Transmission: 5
Easiest way to check it: replace it. It's what, $3? If you've had the car for more than 2 years and you haven't replaced it, it's due anyway.
A bad rad cap won't make your car overheat. What it will do however, by failing to maintain the proper pressure in the cooling system, is to allow the coolant to boil. This is often mis-diagnosed as "overheating", because it sure looks alot like overheating when coolant and steam is spewing everywhere, although in fact the temperature of the engine might be completely normal.
ICON Motorsports
ICON Motorsports
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
