idles fine in park but not in gear
Old Apr 14, 2005 | 04:48 PM
dukemushroom1's Avatar
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
Basically it's just that. When I start it up it runs really well, idles fine, revs good. But once I put it in gear it tries to die and gets really jumpy when accelerating.
Old Apr 14, 2005 | 05:31 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
First guess would be that it's leaning out a bit. Try unhooking the pcv valve and plugging the line for a couple days, if you see an improvement you can go from there. Maybe increase fuel pressure or something/ This might only apply to a cold engine in open loop though.
Old Apr 14, 2005 | 05:43 PM
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
Guess I should have mentioned it's carbed. Sorry
Old Apr 14, 2005 | 06:08 PM
sellmanb's Avatar
Car: '86 Berlinetta
which carb are you running? Sounds like a carb problem.
Old Apr 14, 2005 | 06:27 PM
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
it's a holley 750cfm 4bbl...the 4150 i believe. Thing is, it was running fine a few weeks ago. I had to park it for about 2 weeks cause I couldn't afford gas for it and now it's like this.
Old Apr 14, 2005 | 08:19 PM
sellmanb's Avatar
Car: '86 Berlinetta
fuel filter?
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
jbd1969
Aug 17, 2015 07:06 PM
