Oil Leak Near Fuel Pump
Old Aug 3, 2001 | 11:33 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
The motor is a ZZ4 and it has the external pump mounted on the engine. I started noticing a spot on my driveway, so when I looked under the car the area around the fuel pump was wet. From what I can tell the fuel pump mounts to a metal plate which intern mounts onto the side of the motor. I don't see a gasket there, so I am wondering if it is a metal to metal seal. What can I do to stop this leak? I also am wondering why oil is present where the fuel pump is located. Is it to lubricate the fuel pump shaft?
By the way I'm almost positive the oil is coming from there, because the whole top half of the motor is dry and the fuel pump area is where it is the most wet.
Old Aug 3, 2001 | 11:40 AM
sleeper's Avatar
The mechanical fuel pumps have a pushrod on them that operates off the camshaft.
Yes there are two gaskets on the fuel pump. One is the shape of the metal plate, the other is the shape of the pump.
Old Aug 3, 2001 | 12:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
On the front of the motor, just around the corner from the fuel pump, there are 2 bolt holes. Are there bolts in them?
If you look into the top one, you'll see the fuel pump pushrod exposed. Put a short bolt (½") in that hole with some silicone on it.
ICON Motorsports
89GTAOz
May 16, 2020 09:31 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
